Simple Phillips Curve Model Estimation
obviou191
Postby obviou191 » Tue Jan 24, 2012 9:20 am
Hi everyone,
I was wondering if I could get any advice/comments on the following. I am looking to run a simple Phillips curve model from 1980 to 2010 using quarterly data. I have selected my dependent variable (which is obviously inflation) along with two independent variables of lagged inflation and the output gap. I have completed the necessary unit root test etc. I then ran the following in Eviews....
ls inflation c inflation(-1) output_gap
I was just wondering if this is the correct command for such a model. The results I returned with look pretty good, just want to ensure I have taken the correct approach.
Any feedback would be great,
Thanks,
Carlos
Re: Simple Phillips Curve Model Estimation
Postby startz » Tue Jan 24, 2012 9:27 am
You should probably correct for serial correlation. There is also the question of whether either of the RHS variables are correlated with the error term.
obviou191
Postby obviou191 » Wed Jan 25, 2012 2:53 am
Startz,
Thanks or your reply. I have corrected for serial correlation by adding lagged values to all variables. Is this sufficient?
Postby startz » Wed Jan 25, 2012 5:22 am
You should test for remaining serial correlation using the test under residual diagnostics.
