I have a series of CPI YOY% data which needs to be in logarithmic form. The problem is a small handful (maybe 6 or 7 out of the total 60) are negative values which obviously cannot be logged. I was wondering how this could be overcome or remedied on Eviews. Any feedback would be great.
Thanks,
Shane
Negative Values in Time Series
Re: Negative Values in Time Series
Are you sure inflation needs to be logged? It's relatively unusual to log a percentage rate of change.
As you point out, you can't log a negative number. This has nothing to do with EViews.
Sometimes people add a small positive constant to the entire series before taking the log. At a mechanical level, that let's one proceed but it's not really the same.
Hi Shane,
Not sure if you tried to log a % rate of change, but if you did, it's wrong.
Since the rate of change is defined as "P(t)/P(t-1)-1," you should consider adding back 1 and log it, which will become "log(P(t))-log(P(t-1))" now.
Inflation in annual term can't be higher than 1, so converting to log rate like this won't yield any negative values I reckon.
Hope this helps.
Hope this helps.
