You need EViews 7.1
ZAURoot (Zivot-Andrews Unit Root test)
Re: ZAURoot (Zivot-Andrews Unit Root test)
Dear all
I have problem to use ZAUROOT test! I already installed SAUROOT add-ins in my eviews 7. but when I open the object of the series, there is not ZAUROOT option! but in proc there is add-ins option and it shows ZAUROOT test, but it does not work!
I appreciate alot if you help me that how can I run this test on eviews?
Best wishes
Niaz
Best wishes
Niaz
Could you be more specific as to what "does not work" means?
Thanks for your prompt reply!
I mean that when I click on Zivot and andewrs option which is built in "proc" of the series nothing happen and I dont see any windowns be opened to specify ZAUROOT properties and run the model. I would appreciate if you tell me is it the true way that Im using to do ZAUROOT?
Best
Niaz
Best
Niaz
Nothing happens at all? When you click on Proc->Add-ins->Zivot-Andrews unit root test, a dialog should pop up asking you to specify the test.
yes, thats the problem! I tried it several times but I didnt get any result! thats really strange, do you have any idea about it?
What's the build date of your copy of EViews? (available from help->about eviews)
build date is Oct-10 2011, and refresh date is Jan 08 2012
It should work then. Try posting your workfile.
here is my workfile, Im going to perform ZAUROOT for lnco, lngdp, lnpo!
Thanks alot, the problem is solved, I uninstalled and reinstalled in again and now its working!
as the last question, would you please guide me to interprete the results. here I have some confusing results, for example my t-statistics is -2.59 and 10% critical value is -4.58, therefore the null can not be rejected, but the pvalue is 0.08 which indicates that the null is rejected at 10% significance level!
Dear Gareth,
When I apply the ZAURoot add-in the printout says that "Null Hypothesis: LNGDPPC has a unit root with a structural break ...". Why is that? Isn't the null hypothesis a random walk without structural break?
Kind regards,
László
Kind regards,
László
I would like to use the Add-ins fuction, currently i am using the eviews 7 and i have downloaded the upgrade version to eviews 7.2. In my eviews window is see the add-ins however when i click on object and view options it indenticate that none available for this window. I try to download add-ins and manage add-ins program also, but it does not work. May I know why?
