Hello
Given a return series, I would like to create a dummy variable for the maximum and the minimum return values and remove these values from the return series. How should I go about to do that in eviews6?
dummy variable
Re: dummy variable
It isn't 100% clear what you're asking, but something like:
series dummy=0
smpl if x=@max(x) or x=@min(x)
dummy=1
smpl @all
Re: dummy variable
This is exactly what I was looking for but now how do I remove the maximum observation from the original series x?
Re: dummy variable
Define "remove".
Re: dummy variable
Say we have data from 01/01/2000 to 31/12/2005 and the maximum value is at 04/03/2002. By remove, I mean I would like to delete or say trim the observation at 04/03/2002.
Re: dummy variable
Most everything in EViews operates on the current sample. You can specify which observations to include with the smpl command. For example,
smpl if not dummy-
nayana3012
Re: dummy variable
hi all, can somebody help me as to how to create dummy variables in eviews.\
infact i want to create dummies for post and pre crisis of 2007 and I want to create seasonal dummies also since my data is quarterly. can somebody help me as to how i can create those 2 dummies??thank you please!!!
