Eviews 7: Dummy variable creation
lnp3
Postby lnp3 » Sat Dec 10, 2011 7:54 am
Dear list,
I have already entered panel data in excel. how does Eviews recognize dummy variable after importing into eviews?
does it require special coding? I have two dummy variables. Can i give the same code (1-0) for each of the variables? or should I use a different code for financial crisis?
1) Ownership dummy= Ownership dummy representing domestic ownership; 1 when a bank is owned by a national; 0 otherwise (foreign)
2) financial crisis dummy: binary variable that indicates the state of the economy "crisis" or "normal" crisis=1, normal=0
here are my dummy variables in excel.
please help!!
dummy.xlsx
(50.96 KiB) Downloaded 885 times
Postby EViews Gareth » Sat Dec 10, 2011 8:29 am
What it your question?
lnp3
Re: Eviews 7: Dummy variable creation
Postby lnp3 » Sat Dec 10, 2011 3:38 pm
my question is the following:
after I import panel data into eviews, do I have to write a special code for dummy variables?
in other words, do dummy variables need special rearrangement/ or coding after being imported into eviews or do I treat them like other variables?
I hope it is clear.
Postby startz » Sat Dec 10, 2011 4:15 pm
A dummy variable is like any other variable.
By the way, in the Excel file you posted it looks like the dummy variables are miscoded.
lnp3
Postby lnp3 » Sat Dec 10, 2011 8:45 pm
thanks for the response.
you mean financial crisis dummy was miscoded. right? I have figured out the problem.
crisis=1, normal=0 (btw, does it matter if crisis is 0, normal is 1?)
I hope this is correct now. can you double check the attached file?
thanks a lot again.
dummy(4).xlsx
(51.04 KiB) Downloaded 920 times
