someone help me
i wrote equation cointeg.ls(h) {%equation_cointeg} but the eviews keep showing me up the same message
"alpha series in specification - %dowjones c %brentoil - @EXPAND can convert to catagorical dummies in cointeg.ls(h) %dowjones c %brentoil%
why??
regards
commands Error
Re: commands Error
%equation_cointeg=%dowjones +" "+"c"+" "+ %brentoilRe: commands Error
But with that command it doesn t show me up no equation of cointegration in my eviews "environment"
The next commands that i have are:
i) cointeg.makeresids residcointeg
ii)series z=residcointeg(-{%d})
iii)sort z
regards
iii)sort z
regards
Re: commands Error
That correction refers to the beginning of your code:
Replace the last line with the following:
%dowjones="DJ"
%brentoil="BO"
%equation_cointeg="%dowjones c %brentoil"Code: Select all
I replaced it but doesn t appear anything in my environmment when i run.
The NeXT command are well written??
Thank you
Thank you
Re: commands Error
replaced again and doesn t work :(
Re: commands Error
Have you adjusted your equation accordingly?
equation cointeg.ls(h) {%equation_cointeg}Re: commands Error
Trubator,
in the beggining of my codes i replaced to" %equation_cointeg=%dowjones +" "+"c"+" "+ %brentoil" and then
to calculate de equation cointegration i put equation cointeg.ls(h) {%equation_cointeg} and , even so, it doesn t work.
