I changed the fontsize of the eviews output (eviews7). if i try to look the regression output now, it does not show anything exept some black bars. after setting all the settings back, the problem remains. i can see everything else (tables, graphs, representations) without a problem.
does anyone have an idea how to fix this?
Thank you!
Regression output does not show
Re: Regression output does not show
Just as a check, is your version of EViews up to date?
Yes it is the latest version.
What is the exact build date of your copy (available from Help->About EViews).
Same problem here! I've tried removing the program and reinstalling - does not help. Opening the same workfile on another computre shows no problems - all cells are normal. When freezing the output and looking at the Cell Format, noticed the point size is 1, but altering it won't stick. Please anyone with ideas how to fix this, help...
- build date Jan 7 2010.
Update to the latest version.
