2 variables and 2 cointegrated eqns.
Re: 2 variables and 2 cointegrated eqns.
Good news. Testing for Granger causality works just fine on stationary series. Forget about cointegration. Search for Granger causality in the help system.
so if the series are I(0) what i have to do to go to the granger causaity?
thnx a lot for the valuable help!! and some last questions
if un is I(0) and inflation is I(1)??? can i do something or not???
also i saw an unemployment rate serie which was stationary in levels in 10% sigificance level by ADF test but in Phiplis Peron test wasn stationary in levels?? then what i do! i mean i follow ADF or PP!!
deleidimatteo
hi,
I am studying causality between 2 interest rate: central bank interest rate and lending commercial bank interest rate.
both series are I(1) at level and the probability of integration at the first difference is equal to zero.
when I estimate the Johansen cointegration test between the 2 variable the result is: 2 cointegrating equantions. what does it mean?
moreover, i can't estimate the VECM imposing 2 cointegrating eqns. because the number of variables must be greater than the number of cointegrating eqns.
even if the results of Johansen suggest 2 cointegrating eqns, can I estimate the VECM imposing just 1 cointegrating equation?
thank you in advance.
Matteo
Matteo
