Gobbled program file
ScottGilbert
I wrote and ran and Eviews program file (A.prg). It ran fine in many updates to it. A further tweak caused EViews to crash, an on booting up EViews I found that the A.prg file was no longer on my hard drive, only its phantom A.rg existed. Has an EViews gremlin gobbled my program file? And could an elf within A.rg restore it? (does A.org have the text of the code for A.prg, and if so can I extract it?)
Re: Gobbled program file
Surprised that the .prg is missing since we really don't do anything with the file except read the contents. Unless you were in the act of saving the file.
The ~rg file should be the last backup of the prg file.
Rename the ~rg to prg...
ScottGilbert
:D Thanks Glenn! Handy having the backup file.
Now that you've used up your backup, make sure to make another one :D
Hello
I've got the same issue . How to do get the prg file from an RG file . I'm not sure what you mean by rename it from rg to prg that's the file type
Indeed, you have to change the type.
