White Heteroskedasticity-Consistent Standard Errors
msiamj
Postby msiamj » Sun Jun 19, 2011 10:32 pm
Dear all,
I am currently using Eviews 6 to test my cross sectional data. By using White test, I found a heteroscedasticity problem in my result. Thus, following the guide, I try to solve this problem using "Heteroskedasticity Consistent Covariance" in Estimate Equation. The result shows an increase in coefficient's standard error, but when I try to test the estimated result with White test, the p-value remains the same. Am I done the steps wrongly? or the way I test is wrong? Is it correct if I test the result using White test again for heteroscedastocity like what i did?
May I know what is the correct way of using Heteroskedasticity Consistent Covariance to eliminate the heteroscedasticity in my model?
Thanks in advance.
learner
Re: White Heteroskedasticity-Consistent Standard Errors
Postby learner » Sat Sep 15, 2012 8:21 am
Dear Sir
The same is problem with me, did you find the solution.
It would be nice of you if you sahre it .
Postby startz » Sat Sep 15, 2012 9:28 am
White's method does not eliminate heteroskedasticity. It corrects the standard errors to account for the heteroskedasticity.
