Exporting data to a specific excel sheet using "pagesave"
maragloria
Postby maragloria » Tue May 31, 2011 12:56 pm
Hi there,
I am try to send some data to an excel sheet using the command pagesave.
Here is my complete code:
'excel file holding signals - IT CANNOT BE A "xlsx" %xlsfile = "X:\Equi_Val_Exc_G10\source_modeles_structurel.xls" pagesave(t=excel) %xlsfile range=facmod_v1!A1 @keep sig_* @smpl 1990m01 @last pagesave(t=excel) %xlsfile range=facmod_v2!A1 @keep sig_* @smpl 1990m01 @last
Once the code runs, all but one excel sheet disapears. The only one remaining is named "source_modeles_structurel" (as the file name) instead of
"facmod_v2" and "facmod_v1" as I intend to do (these 2 sheets were created prior to runing the code).
How can I refer to a specific excel sheet using the pagesave command? Is there a better command?
I use Eviews 7.
Thanks a lot,
Mara
Re: Exporting data to a specific excel sheet using "pagesave
Postby EViews Glenn » Tue May 31, 2011 2:12 pm
Unfortunately, pagesave won't write into an existing Excel file...
maragloria
Postby maragloria » Wed Jun 01, 2011 5:48 am
Should I use the EViews Excel Add-in instead?
Postby EViews Glenn » Wed Jun 01, 2011 8:23 am
Yes. I should have mentioned that the new Excel tools should give you better flexibility since you are coming from the Excel side rather than the EViews side.
maragloria
Postby maragloria » Wed Jun 01, 2011 11:35 am
Ok, thanks a lot. I'll try that.
