Impulse Response with 1 standard error
byront
Postby byront » Sun May 01, 2011 5:19 pm
Hi all:
The default when plotting the impulse response from a VAR is +/- two standard errors. Following the most of the literature, I want to plot with 90% confidence intervals instead. What is the easiest way to do it in EViews?
Thanks!
Byron Tsang
Re: Impulse Response with 1 standard error
Postby EViews Gareth » Sun May 01, 2011 6:36 pm
You can view the impulses, and the standard errors as a table. Then you can calculate/plot whatever you want with the raw data.
