I want to do panel unit simulation.
BUT I don't know how to write the LLC and IPS in program. can they write as @LCC,@IPS?
can you help me?
Thanks!!
how to write LLC and IPS test in program
Re: how to write LLC and IPS test in program
Look up the uroot entry under the Series section of the Object Reference.
thank you
but Iwo can't find it
can you say detail
can you say detail
Sure.
From the help menu, click on Object Reference (pdf). Once it is open, navigate to Chapter 1. Then navigate to the section of Chapter 1 that is for Series. The objects are in alphabetical order, so Series comes after Scalar and before Spool. Once you're in the Series section, navigate to the part about uroot.
thanks a lot!
