fixed effect standard errors
mpiuser
Postby mpiuser » Tue Feb 01, 2011 2:27 pm
I did a simple un-balanced panel regression including a constant and cross-section fixed effect as regressors. I can recover the fixed effects (up to a constant of course) by viewing them.
How can I recover the standard errors for the fixed effects. The covariance matrix only includes the standard error of the constant.
I realize that I can generate dummy variables and include them explicitly in a simple regression, in which case the covariance matrix will include them. But, I have many thousands of cross-sections so this would be incredibly tedious.
Cheers.
sdstest
Re: fixed effect standard errors
Postby sdstest » Mon Apr 11, 2011 1:24 am
I was also wondering about this. Did you eventually get some advice? Or did you find the solution yourself?
Postby EViews Glenn » Mon Apr 11, 2011 11:23 am
As you have discovered, EViews treats the fixed effects as nuisance parameters so that standard errors aren't reported. My recollection is that for non instrumental variables/non-weighted cases, it's not that difficult to compute these after the fact, but you're going to have to go to the literature to find the exact formulae.
Postby EViews Gareth » Mon Apr 11, 2011 11:53 am
You could use dummies, but you may hit memory problems if you've got a huge number of cross-sections.
You can create the dummies easily using @expand(@crossid), or something similar.
