Overflow error in GARCH-M
kco5min
Postby kco5min » Sun Apr 03, 2011 12:09 pm
Hi All,
I am runnig a AR - GARCH-M model of inflation and inflation uncertainty proxied by the errors of conditional mean ecuation.
The code is:
INFLATIE = C(1)*GARCH + C(2) + C(3)*INFLATIE(-1) + C(4)*DUMMY*INFLATIE(-1) + C(5)*INFLATIE(-2) + C(6)*INFLATIE(-4) + C(7)*INFLATIE(-6)
GARCH = C(8) + C(9)*RESID(-1)^2 + C(10)*GARCH(-1) + C(11)*INFLATIE(-1)
(inflatie=inflation)
The model runs perfect, but when i'm trying to conduct tests for errors anf coeffcients , Eviews says " Overflow". Why is this happening?
Can you help me please.
Thx in advance
Re: Overflow error in GARCH-M
Postby EViews Gareth » Sun Apr 03, 2011 12:42 pm
Could you post the workfile?
kco5min
Postby kco5min » Sun Apr 03, 2011 10:46 pm
Thx Gareth for the fast reply.
Attached you will find my workfile. The Garch model is named grach-m.
Thx,
ar_framework_2.wf1
(47.2 KiB) Downloaded 266 times
trubador
Did you use forum search?
Postby trubador » Sun Apr 03, 2011 11:35 pm
It seems your model is ill-defined. The problem arises from the fact that the variance specification does not fulfill the stationarity condition (i.e. c(9)+c(10)<1). I can offer two solutions:
i) I do not think it is a good idea to include the lagged dependent variable as an exogenous variable in the variance equation, so it might be a better idea to drop it.
ii) If you want to keep the exogenous variable in the variance equation, try including the standard deviation instead of variance as the garch-in-mean specification.
kco5min
Postby kco5min » Mon Apr 04, 2011 12:40 am
Thx @trubador.
I will keep the lagged dependent variable of inflation because I am intending to test both influences bettwen inflation and its variance, in both directions.
I've changed the specifiaction to std dev and it works perfect.
Thx a lot :)
kco5min
Postby kco5min » Sat Apr 09, 2011 4:39 am
Since i've used std dev instead of variance in the mean equation Eviews showed me all the test that i needed, but still I have the stationarity problem and I really dont know how to solve it.
The coefficient restrictions c(9) + c(10) = 1 showes a p-value of ,8990 even after I've included std dev in the conditional mean.
How can I repair this stationarity problem?
Thx in advance
