eviews 7: creating age category dummies
totallyheart
Postby totallyheart » Thu Mar 24, 2011 7:48 am
I'd be really grateful if someone could help me...
I need to create 7 age category dummies for my regression.
My age categories will be:
< 20 (which i will use as my reference group so dont need a dummy)
21-30
31-40
41-50
51-60
61-70
71-80
> 80
Im using eviews 7 and have tried the following to create my first category dummy:
series dum_1
smpl @ all
dum_1 = 0
smpl 21 30
dum_1 = 1
which didnt work :(
please can someone help?
thank you!
Re: eviews 7: creating age category dummies
Postby EViews Gareth » Thu Mar 24, 2011 7:50 am
Do you currently have a variable that contains age information?
Postby EViews Glenn » Thu Mar 24, 2011 9:11 am
To expand on Gareth's comments, the smpl statements you employed were using the order of observations in the workfile to define the dummies not the ages.
Assuming that you have an age variable. If all you want to do is use the dummies in an equation, you can do this in two steps:
1. use the Proc/Generate by Classification series proc and the age variable with your specified limit values to create an index variable (0, 1, 2... ) with the age categories (series proc name classify).
2. use the @expand function on your newly created index variable to create dummies on the fly for use in the equation.
Check the documentation for Classification, from series for a discussion of the classification proc.
totallyheart
Postby totallyheart » Fri Mar 25, 2011 12:54 am
thanks for getting back to me so soon.
Im sorry to be a pain, but as im a beginner to eviews i didnt quite understand the steps to creating these dummies.
If you could go over it in layman terms it would be great! :) ...
Postby EViews Gareth » Fri Mar 25, 2011 7:53 am
totallyheart
Postby totallyheart » Sat Mar 26, 2011 6:31 am
yes, i do
Postby startz » Sat Mar 26, 2011 7:51 am
Try
series dum_1 smpl @all dum_1 = 0 smpl if age>=21 or age<=30 dum_1 = 1
Postby EViews Glenn » Mon Mar 28, 2011 9:32 am
I assume you mean "age < 21" for your first category.
The code
age.classify(method=limits) 21 31 41 51 61 71 81 @ agecat
should create your age category variable AGECAT.
Then in your regression specification, you can do
equation eq1.ls y c @expand(agecat, @dropfirst)
which will create the dummies in the regression, dropping the first category.
