pagecontract
javiersan
pagecontract
Postby javiersan » Sun Mar 13, 2011 4:33 pm
I have an alpha where the first two observations are the same. If I do pagecontract x<>x(-1) none of the two observations are kept when I think one of them should be.
Is there a way around this?
Thanks,
Javier
Re: pagecontract
Postby startz » Sun Mar 13, 2011 5:49 pm
Check the following...
First observation, x<>x(-1) is false because x(-1) is NA
Second observation, x<>x(-1) is false because it's really false.
(But I haven't checked this myself.)
Re: pagecontract
Postby EViews Gareth » Mon Mar 14, 2011 8:07 am
Dick is correct.
A quick workaround would be something like:
series i = x = x(-1) pagecontract if i=0
javiersan
Re: pagecontract
Postby javiersan » Mon Mar 14, 2011 8:23 am
Unfortunately that still doesn't work as the first observation is deleted (i.e. i(1)=na so obs 1 is not kept).
I would have expected that for these comparisons the starting point would be observation 2 and the first comparison would be obs 2 vs. obs 1. The comparison of obs 1 vs obs 0 is an impossibility as obs 0 does not exist and it does not make sense to compare something that exists with something that does not exist.
The solution is this
series i = x = x(-1) i(1)=0 pagecontract if i=0
but I just wonder whether the way the comparison is performed is not inconsistent.
Regards,
Javier
