Hello!
Are the Panel Cointegration technique and Fully Modified Ordinary Least Square already available in Eviews? In which version? Thanks! :D
Panel Cointegration Technique and FMOLS
Re: Panel Cointegration Technique and FMOLS
Panel cointegration is not built into EViews. FMOLS is available as a built in procedure.
bleuenrouge
Okay, thank you very much for your reply. :)Panel cointegration is not built into EViews. FMOLS is available as a built in procedure.
bleuenrouge
Lastly, Does it mean I can no longer use Eviews for Panel Cointegration? I would just like to know because I will be using the Panel cointegration test and Fully Modified Ordinary Least Squares using "Panel Data."Panel cointegration is not built into EViews. FMOLS is available as a built in procedure.
Thank you again. :)
Panel cointegration testing is built into EViews 7, however panel cointegration estimation is not.
bleuenrouge
Thank you for your reply. :)Panel cointegration testing is built into EViews 7, however panel cointegration estimation is not.
