Eviews wishlist
Eviews wishlist
The suite of string functions in EV7 vs EV6 improvement was just fantastic and I'm sure you have a few other tricks under your sleeve for EV8 but I have listed below my wish list of the features I would love to see in a new version. I know, it's not Chritmas yet...
Charting
ability to show charts with double time axis (see post: http://forums.eviews.com/viewtopic.php?f=5&t=3616 at the bottom)
chart-type with bottom axis [t-12 to t+12] for multiple series (see same post and Gareth’s solution);
addtext to allow vertical text and justification;
combination of charts: stacked bars + lines, multiple fitted lines in scatters, etc.
Allow labels in bottom axis to be aligned vertically (or in other directions);
Allow to retrieve the characteristics of charts, such as axis scale (min/max, step), date ranges, size (in virtual inches for example), etc. something like: !min=mychart.@leftaxismin
Allow addtext to include carriage return (ASCII 13 or equivalent) and to justify text
Allow addtext to position text using axis coordinates (i.e. not virtual inches) such as mygraph.addtext("2008q3",-0.15) Trough in GDP
Graph shading via criterion, such as if X>0, where X is the X axis variable.
Databases
Ability to query series from a database without having to fetch it (e.g. what is the start/end date, native frequency, etc.) something like: %freq=mydb::myseries.@frequency
Ability to incorporate notes to databases (like long descriptions, etc.)
File opening
Ability to read XML files and html/csv/xls files “behind” .asp type of webpages (e.g. http://forums.eviews.com/viewtopic.php?f=5&t=3555)
Econometric techniques
Incorporate the Pooled Mean Group estimator and Westerlund's panel cointegration tests;
Program editor
Add code line numbering;
VB for excel capabiities: ability to pause and resume code, ability to run part of code, track variables values,
Functions
Inclusion of financial formulas in particular IRR and NPV based on cash-flows defined in a series and with calculations at a given date (e.g. if the cash-flows of an investment are defined in series CF the formula form could be IRR(CF,”1990m1”,-10) where -10 is the initial investment, and NPV(CF,”1990m1”,0.1) where 0.1 is the discount rate p.a.)
Charting
Databases
File opening
Program editor
Functions
Re: Eviews wishlist
Nice list. Some of them are already in the works.
Re: Eviews wishlist
A few more...
It could be great if there was a command that closed all the non-workfile "windows" (graphs, series spreadsheets, groups, equations, etc.) and another command that closed all the workfiles (and opened databases).
As well, for those of us that store all databases in the same folder, could it be possible to add a "default database folder"? There is no discussion of that on http://www.eviews.com/download/whitepapers/Paths.pdf.
Re: Eviews wishlist
close @all
close @objects
Re: Eviews wishlist
Any way to close the workfiles & objects but not the programs? close @all closes the program(s) as well.
Re: Eviews wishlist
Not currently, but I can add it to the suggestions list. Something along the lines of
close @wf
close @db
close @prog
Re: Eviews wishlist
One more from your original list - you can use "\n" to add a carriage return in the addtext command.
Something like:
Something like:
graph.addtext "hello\nworld"
Re: Eviews wishlist
Brilliant.
I tried to use it in the context of an alpha series that would be used to label the axis (see your last comment on http://forums.eviews.com/viewtopic.php?f=5&t=3616) but it doesn't do the trick.
Re: Eviews wishlist
No, :(
Re: Eviews wishlist
To add to the list above, would it be possible to allow for saving tables as image files (wmf/emf and the like)?
Thanks,
Javier
Thanks,
Javier
Re: Eviews wishlist
Has the ability to retrieve the characteristics of charts, such as axis range, etc., been incorporated into Eviews 8? This would be a useful feature to have.
Re: Eviews wishlist
No :(
