Hi, I recently started using eviews (v7) and I have a very basic question.
I am using time series and I want to generate the sum of a number of variables. Why do I get different results when using the @sum command (I get the wrong result) than when typing the whole sum equation (e.i: A=b+c+d) when I do manage to get the correct sum.
What I want is to generate a horizontal sum (summing rows). Anyone knows why the @sum command is generating something different than what I want?
These are the two codes I'm using:
series comp_ind= @sum(stand_indep{!j}) .......[this is not generating the correct sum]
series comp_ind2=stand_indep1+stand_indep2+stand_indep3+stand_indep4+stand_indep5+stand_indep6+stand_indep7 ........[does generate the correct sum]
Thanks!
Horizontal vs Vertical sum?
Re: Horizontal vs Vertical sum?
Put the variables into a group, then use the @rsum command:
Thank you very much Gareth!
