setobslabel(series) order of events
bhaupt
Postby bhaupt » Tue Feb 01, 2011 3:27 pm
I am using the latest build of eviews 7.1.
I want to use an alpha series in place of my date series along the bottom axis. If I build the graph through the menus and options, it works properly; however, if I try to use te setobslabel in my code it seems to not work.
I assume I have a contradictory statement or something that overrides my alphaseries and forces it to the date series.
As such, I have included all subsequent graph commands for inspection.
for %ser FOO BAR group g_{%ser}_gph1 {%ser}_exmpl_sa {%ser}_exmpl_tr mean_exmpl_sa mean_exmpl_tr graph gr_{%ser}_gph1.line(x) g_{%ser}_gph1 ' Here's the setobslabel command gr_{%ser}_gph1.setobslabel(series) alp_yr_name gr_{%ser}_gph1.axis(l) textcolor(black) overlap units(k) font("ariel",10,b) range(0,!testmax1) gr_{%ser}_gph1.axis(b) textcolor(black) font("ariel",10,b) gr_{%ser}_gph1.setupdate(a) gr_{%ser}_gph1.addtext(t, textcolor(black),font("ariel",8,b)) %titlestring gr_{%ser}_gph1.addtext(l, textcolor(black), font("ariel",10,b) ) "My Units (K, SA)" gr_{%ser}_gph1.addtext(b, textcolor(black),font("ariel",10,b)) "Normalized Monthly Data" gr_{%ser}_gph1.legend -display gr_{%ser}_gph1.options linepat gr_{%ser}_gph1.setelem(1) lcolor(black) lpat(1) axis(l) gr_{%ser}_gph1.setelem(2) lcolor(blue) lpat(1) axis(l) gr_{%ser}_gph1.setelem(3) lcolor(black) lpat(2) axis(l) gr_{%ser}_gph1.setelem(4) lcolor(blue) lpat(2) axis(l) next
EViews Pamela
Re: setobslabel(series) order of events
Postby EViews Pamela » Tue Feb 01, 2011 4:51 pm
You are correct that it is an ordering issue. The setupdate command changes the fundamental behavior of a graph. I would suggest calling it before setting other attributres such as color, labels, etc.
bhaupt
Postby bhaupt » Wed Feb 02, 2011 7:16 am
Thanks - that was exactly it.
