Dynamic Panel Method/AR(1) & AR(2) test
mofar
Postby mofar » Wed Jan 26, 2011 8:37 am
Is there a practical way to test the first and second order serial correlation in the residuals after estimating GMM (AB) model in Eviews 7.1?
Any feedback is very appreciated.
Thank you,
Re: Dynamic Panel Method/AR(1) & AR(2) test
Postby EViews Gareth » Wed Jan 26, 2011 9:05 am
Unfortunately not. It is one of the things that should be added in EViews 8 though.
mofar
Postby mofar » Wed Jan 26, 2011 9:59 am
Thanks. But Do you have any idea regarding calculating these tests manually using output of GMM estimations? Something like Sargan test which can be calculated manually...
