Problem with Group Objects
PhilW
Postby PhilW » Thu Dec 02, 2010 8:18 am
Group objects automatically upper case all names when the group is updated. This is usually fine as native variable names are not case sensitive. However if any variables include a string comparison then the comparison text is also made all upper case leading to a the comparison always being false.
Example,
city="Miami" -- Sometimes true,
by updating the group is converted to
CITY="MIAMI" -- Never true.
The variable city=CITY,
but the text "Miami" ne "MIAMI".
Eviews 7.1 build Nov 11, 2010
Re: Problem with Group Objects
Postby EViews Gareth » Thu Dec 02, 2010 8:53 am
I want to ensure that this is what you're saying.
You have a group object with the auto-series:
CITY="Miami"
in it (that would essentially return a value of 1 or 0). When you update the group this changes to
CITY="MIAMI"
which then invalidates the auto-series.
Yep, I can see that would be a problem. I'll see if we can upper without quotes it.
Postby EViews Gareth » Thu Dec 02, 2010 10:31 am
The latest patch should fix this issue for you.
