I'm writing a thesis about the Performence of Minimum Variance Hedge Ratios wich are determined by multivariate GARCH models. Therefore I would like to do conduct a 1-day/1-week ahead out-of-sample forecast of the conditional variance/covariance produces by the GARCH Model. I manage to generate the conditional variances of multivariate GARCH Models, e.g. the Constant conditional correlation model for a With-in-sample comperison through the standard "make covariance" function. I tried to create a model object from the estimated CCC Model in order to perform a out-of-sample forecast, but the model object as far es I know does not allow to extract the conditional covariances/variances into a seperate series (what I need to determine the hedge ratios). Does anyone know how to manage this task or has someone programmed a solution for my out of sample problem? I'm realy thankfull for answers as I'm have a timeproblem to finalise the thesis without a solution to this!
Thanks a lot in advance!!
Flo
Out-of-sample forecast of multivariate GARCH Models
Re: Out-of-sample forecast of multivariate GARCH Models
I think it will be a better approach to produce a custom-made solution to your need, since you have a time constraint. I suggest you to share your workfile and provide more information on your model (e.g. variables, definitions, etc.), if it is OK for you. Right now I am very busy, but I will try to build a code for you as soon as I am available. Hence, I need to know your deadline on this issue. In the meantime, other members of the forum or moderators may also help you.
Hi there,
I face the same problem as F_B. Here is my workfile and the information about the model I want to build. Could you give some help?
Many thanks.
Many thanks.
- data.wf1
- (42.26 KiB) Downloaded 701 times
- model information.doc
- (24 KiB) Downloaded 695 times
The following inefficient yet effective piece of code should be doing what you want:
'First order model (BEKK-GARCH(1,1)) is assumed.
sym(2) M
vector(2) A1
vector(2) B1
'Create a system
%sys = "sysbekk"
system {%sys}
{%sys}.append duks = c(1)
{%sys}.append dukf = c(2)
'Estimate the system as diagonal BEKK
smpl @first @first+368
{%sys}.arch @diagbekk c arch(1) garch(1)
'Save the conditional series
{%sys}.makegarch
'Compute the in-sample hedge ratio
series hr = garch_02/garch_01_02
delete garch*
'Rolling forecasts
for !i=1 to 154
smpl @first @first+368+!i-1
{%sys}.makegarch
{%sys}.makeresids
'Generate new series for forecasted variables
for %y GARCH_01 GARCH_02 GARCH_01_02 RESID01 RESID02
series {%y}f= {%y}
'Organize the estimated coefficients into matrix form.
'Constant is assumed to be the only exogenous variable in each mean equation.
'Therefore coefficients of variance specification should start at c(3).
M(1,1)={%sys}.@coefs(3)
M(1,2)={%sys}.@coefs(4)
M(2,2)={%sys}.@coefs(5)
A1(1)={%sys}.@coefs(6)
A1(2)={%sys}.@coefs(7)
B1(1)={%sys}.@coefs(8)
B1(2)={%sys}.@coefs(9)
'Number of observations used in the estimation
!n={%sys}.@regobs
'Define out of sample forecast horizon
!h = 1
'Perform dynamic forecasts via adjusting the sample (do not forget the missing value due to lag structure)
for !j=1 to !h
smpl @first+!n+!j @first+!n+!j+1
GARCH_01f = M(1,1) + A1(1)^2*RESID01f(-1)^2 + B1(1)^2*GARCH_01f(-1)
GARCH_02f = M(2,2) + A1(2)^2*RESID02f(-1)^2 + B1(2)^2*GARCH_02f(-1)
GARCH_01_02f= M(1,2) + A1(1)*A1(2)*RESID01f(-1)*RESID02f(-1) + B1(1)*B1(2)*GARCH_01_02f(-1)
RESID01f = 0
RESID02f = 0
'Out-sample hedge ratios
series hrf = garch_02f/garch_01_02f
'Combine in-sample and out-sample hedge ratios into one series
hr = hrf
delete garch* resid0*
smpl @allRe: Out-of-sample forecast of multivariate GARCH Models
Thank you so much Trubador. It really helps. :D
neat idea!
However, if h>1, the code will not correct.
for example, let h=2, we should compute E_t(e_{t+1}^{2}) when producing conditional variance at t+2 conditional on time t.
