Replace Variables Problem
Ralph
Postby Ralph » Wed Nov 12, 2008 8:21 pm
Hello, everyone:
I'm wondering if a replace variable can refer to another replace variable in Eviews?
for example
create u 50
series x = nrnd
%var1 = "x" 'here I use a replace variable to refer series x
!k = 1 'here I use a control variable as index
My question is how can I create a replace variable %xvar to refer series x THROUGH %var and !k ???
I tried a couple of ways to work it out but they don't work such as
%xvar = "%var" + @str({!k}) 'here I create a string to represent replace variable %var1
series y = {%xvar} 'it doesn't work
or series y = {{%xvar}} 'it doesn't work either
we can do this kind of "double reference" easily in SAS, but I don't know whether Eviews can really do that or not.
regards
Ralph
Re: Replace Variables Problem
Postby EViews Gareth » Thu Nov 13, 2008 12:30 am
I don't believe you can use a replacement variable to refer to a replacement variable like that, no.
That doesn't mean there isn't a way to do what you want. Unfortunately I can't quite follow what it is you're trying to do, so can't offer any advice on how to do it.
lomazzi
Postby lomazzi » Tue Jan 13, 2009 7:28 am
I have a similar problem and I tried several things
!loopmax=22
%1 = "OBLICHFDOM"'
for !loop=1 to !loopmax
show %!loop (This does not work)
Postby EViews Gareth » Tue Jan 13, 2009 9:06 am
As said above, you can't combine replacement variables like that, nor can you refer to a replacement variable with a replacement variable.
I assume you have something like this:
%1 = "OBLICHFDOM"
%2 = "Something"
%3 = "Something else"
and then want to loop through them with a numerical variable.
The easiest way to do this is to not loop through them with a numerical variable, but with a string variable:
for %i "oblichfdom" "something" "something else" statusline %i next
Or, if you really want to use a numerical variable in your for loop, then put the text into a table:
table vars vars(1,1) = "oblichdom" vars(2,1) = "something" vars(3,1) = "something else" for !i=1 to 3 %var = vars(!i,1) statusline %var next
farrel
Postby farrel » Sat Jun 27, 2009 1:19 am
But what I have to do if I want to make a lot of similar names in cells of table like this:
table vars
vars(1,1) = "something1"
vars(2,1) = "something2"
vars(3,1) = "something3"
vars(100,1) = "something100"
Postby EViews Gareth » Sat Jun 27, 2009 8:05 am
table vars for !i=1 to 100 vars(!i,1) = "something"+@str(!i) next
farrel
Postby farrel » Sun Jun 28, 2009 12:53 pm
thanks
