Convert date format
Creditevent
Convert date format
Postby Creditevent » Mon Oct 11, 2010 12:37 pm
Can anyone help me converting a text format (like 200101) into a date format (YYYYMM). It is possible in Excel with the command: "Datevalue". The problem in Eviews is that if am just using "properties - period - date format: YYYY:MM" it is not reading the month and year correctly.
Convert date format
Postby EViews Gareth » Mon Oct 11, 2010 12:47 pm
It isn't clear what you're trying to do. Could you provide more details/context?
Creditevent
Re: Convert date format
Postby Creditevent » Mon Oct 11, 2010 1:07 pm
Thank you for looking at the issue. I will try be more clear. I want to tell Eviews that my the variable "YR" is a date (not a number). I was trying to do that in "properties" -> "period" and "date format = YYYYMon". However Eviews reads 200101 as "0549Feb" - which is wrong (it should be year 2001 and January). Excel does the same mistake - but I can correct this issue by another command. Can Eviews do something similar? Do you follow my problem?
Creditevent
Postby Creditevent » Mon Oct 11, 2010 1:15 pm
eviews.wf1
(8.51 KiB) Downloaded 557 times
Creditevent
Postby Creditevent » Mon Oct 11, 2010 1:18 pm
Thanks. In the attached file you see the variable "yearmon" e.g. "200101" - but Eviews reads "200101" not as "year 2001 and January" but something way different. Can you help me having Eviews reading "200101" as "2001 and January"?
Postby EViews Gareth » Mon Oct 11, 2010 2:33 pm
show @dateval(@str(yearmon),"YYYYMM")
