granger causality test with newey west correction?
kanonathena
Postby kanonathena » Fri Sep 17, 2010 6:33 am
Is there a way to extract the program code of granger causality test so I add newey west correction .ls(n) ? what about codes of other tests in eviews6
Re: granger causality test with newey west correction?
Postby EViews Gareth » Fri Sep 17, 2010 8:11 am
The inbuilt procedures are written in a completely different environment from the EViews programming language, thus there is no way to use the source code (which is proprietary anyway).
Postby EViews Glenn » Mon Sep 27, 2010 11:43 am
I will add, however, that the Granger causality test is easy to run yourself by estimating the corresponding equation(s) using the equation object. Adding Newey-West there is easy. Then compute the Wald test for the lags in question.
