It would be advantageous for us to configure some of our user's settings to be the same, such that graphs looks identical and such that users don't leave a ~RG-file every time they do minor changes in a program.
I see there are some .ini-files, and I assume I will have to make a program that modifies/overwrites the user's file. How do I retreive the path of the ini-file folder for each user?
And any tips on how to modify the ini-files? Does each setting need to be in the order they originally are in and modified in place, or can I append the new settings at the end of the ini-file and the settings will update? How do I modify the graph-settings?
If modifying the files is not the way to go, how would I otherwise solve this?
How do I configure a user's settings/.ini-file?
Re: How do I configure a user's settings/.ini-file?
Most of the .ini files are just text files. The order of the line inside the text files don't matter. You can use any external text editing application to modify them.
Graphics settings are in the Graph ini files. They are not text files, so cannot be modified.
You can copy the graph.ini file from one person to another though.
Users browsing this forum: No registered users and 26 guests
