How to save a graph to use as a template
I am using Eviews 6.0. I created a graph with shaded recession periods. I want to save it as a template so that I can use it repeatedly. When I click the "Manage Predefined Template List", the "Template Management" window jump out. However, it seems I cannot do anything with this window because the "Add" option is disabled...What did I do wrong? Thanks!
- question.png (298.81 KiB) Viewed 16598 times
Re: How to save a graph to use as a template
You have to name your graph before you can use it as a template.
Yes, I get it. Thank you very much!
Hi Gareth,
I wonder how to create a graph template by code.
Is it any named frozen graph can be used as a template? Because I see an option in dialog box but I do not find specific commands or relevant options in graph object methods.
Many thanks,
Many thanks,
There is currently no way to create/save a template by code. It must be done by the user interface. We will look into adding the feature to EViews 11
Many thanks. Hope to see this feature since it helps us when create irf plots from matrix. Applying a template saves a lot of codes.
Tangentially related to this question:
Is it possible to apply a template to a graph programmatically?
Thanks!
Thanks!
Thanks, I was looking through the programming guide and couldn't seem to find it. Could you please provide an example, or incorporate into the text below?
where g_us_0 is a group.
Thanks!
graph mgrus_0.line g_us_0
Thanks!
Users browsing this forum: No registered users and 18 guests
