Tramo/Seats command references
eeeeooorrr
Postby eeeeooorrr » Fri Jul 09, 2021 12:52 am
I have a query in relation to Tramo/Seats.
If I run the following script on a series (I pasted the series as values here for ease), I get a different result with the proc window than I do with the command language even though I think it should be identical.
See the two graphs attached for a comparison.
I also tried using the exact commands captured in capture window, but that just fails to run (see “Attempt 2”).
Any idea how to adjust my attempt at running this so that I can get the same result as is produced by the proc window?
E
wfcreate(wf=Test, page=1) m 2013.1 2021.6
series t = na
t.adjust = 1386.968   1227.182   1051.993   1377.385   1078.66   1169.998   1301.01   1110.658   1107.341   1319.333   2349.146   1278.234   1235.562   1467.736533   1235.876672   1466.459795   1192.488   1233.139   1415.554   1336.576   1184.257   1360.955   2637.145   1391.718   1503.834   1382.937   1354.402   1507.404   1289.845   1270.407   1454.62   1458.669   1222.038   1416.734   2705.744   1792.61   1634.431   1502.93   1218.131   1748.749   1333.021   1333.655   1519.375   1408.408   1254.571   1484.149   3107.39   1624.16   1642.015   1481.516   1293.682   1762.262   1445.038   1420.902   1674.365   1496.762   1388.458   1645   3033   1726   1750   1584   1334   1868   1554   1653   1704   1604   1483.536   1733.464   3187   1787   1883   1589   1501   1992   1760   1767   1727   1861   1672   1837   3530   1815   2198   1780   1665   1877   1623   1399   1589   1755   1543   1584   2512   3186   2283   1751   1835   2120   2177   2042
series dumdate1 = @recode(@date=@dateval("2020m11"),1,0)
series dumdate2 = @recode(@date=@dateval("2020m12"),1,0)
' Attempt 1
t.tramoseats(runtype=ts opt="seats=2 mq=12 inic=3 idif=3 itrad=iatip=1 aio=0 ireg=2", reg="DUMDATE1", reg="DUMDATE2", save="sa") t
' Attempt 2 (taken from capture script and will not run)
t.tramoseats(opt="seats=2 mq=12 inic=3 idif=3 itrad=iatip=1 aio=0 ireg=1", reg="iuser=-1, nser=1, ilong=110", regname=DUMDATE1, reg="iuser=-1, nser=1, ilong=110", regname=DUMDATE2, save="sa") t
graph from code.jpg (22.8 KiB) Viewed 9813 times
graph from proc window.jpg (24.05 KiB) Viewed 9813 times
eeeeooorrr
Re: Tramo/Seats command references
Postby eeeeooorrr » Wed Aug 04, 2021 8:32 am
Would really appreciate a response to this!
eeeeooorrr
Postby eeeeooorrr » Thu Feb 03, 2022 2:57 am
Following up on this again as it's been half a year now with no response.
Postby EViews Gareth » Thu Feb 03, 2022 8:09 am
It is hard to say what commands will match the options you choose when you do it through the proc window, without knowing which options you choose.
Users browsing this forum: No registered users and 30 guests
