date manipulation crashing when month is feb
BT454
Postby BT454 » Thu Apr 29, 2021 11:06 am
Hi all,
This piece of code works for any month, except feb (i..e if the @dateadd determines any month other than feb, it will correctly return the requested date string. But for Feb it returns "?". And unfortunately, Feb is the month I need to assign the string to. Any thoughts?
Thanks!
Bob
close @wf
wfcreate(wf=test) m 2016 2016
!dom=@datepart(@dateval(@date),"dd")
if !dom > 10 then
  %enddate = @datestr(@dateadd(@dateval(@date),-2,"mm"),"yyyy")
  statusline check ok
else
  %enddate = @datestr(@dateadd(@dateval(@date),-3,"mm"),"mm/dd/yyyy")
  statusline check bad
endif
show %enddate
BT454
Re: date manipulation crashing when month is feb
Postby BT454 » Thu Apr 29, 2021 11:08 am
Ah... I bet it's because it's the 29th, and feb only has 28 days this year....
BT454
Postby BT454 » Thu Apr 29, 2021 11:26 am
Is there a way to code a string that returns the first day of the month instead of the current day? I'm playing around with @datefloor but I can't seem to pass the value to a string or scalar.
Thanks!
Bob
Postby EViews Gareth » Thu Apr 29, 2021 12:13 pm
Combination of @datestring and @datefloor
Users browsing this forum: No registered users and 28 guests
