EIA API V2
dman
EIA API V2
Postby dman » Mon Mar 13, 2023 2:34 pm
In an older topic, I was told that EIA APIv2 support was coming soon.
EViews Katerina wrote:We have noticed the instability of getting reply from EIA API as well. We are not sure if it is related to their work on the v2 API. The v1 API will be deprecated (which means no further support) but it should continue to work.
We are working on adding the EIA v2 API in EViews and we will let you know as soon as we release it.
Note that the new version of EIA API does not support the existing series ID. When v2 API is available all fetch commands will have to use new ids.
Has is been implemented yet? The API v1 has been retired as of today.
https://www.eia.gov/opendata/v1/register.php
Opening the EIA via Databases in Eviews 13 no longer works with default server settings.
Are there alternative settings that make V2 work?
I'm aware that I'll have to change variable ID specifications in my code, but so far I'm not even able to browse what's there.
Please fix asap, thanks!
Re: EIA API V2
Postby EViews Gareth » Wed Mar 22, 2023 3:27 pm
Today's patch has v2 support.
Users browsing this forum: No registered users and 40 guests
