Hello everybody, I have a test equation with 6 parameters and I would like to test the hypotheses c(6)>=c(5) against H1: c(6)<c(5).
I have performed a Wald test with c(6)=c(5) and I have a p-value equal to 0. How can I confirm that c(6) is larger or equal than c(5)?
Thank you for your answer.
Test the null hypotheses c(6)>c(5)
Re: Test the null hypotheses c(6)>c(5)
Basically, you just want to do a one-tailed test. See https://en.wikipedia.org/wiki/One-_and_two-tailed_tests for an explanation.
startz wrote:Basically, you just want to do a one-tailed test. See https://en.wikipedia.org/wiki/One-_and_two-tailed_tests for an explanation.
Yes, exactly, thank you. How could I perform it on EViews?
EViews does not have one-tailed tests built in. Go through the steps for a two-tailed test and then compare the t-statistic to the critical value for a one-tailed test from a t-table.
startz wrote:EViews does not have one-tailed tests built in. Go through the steps for a two-tailed test and then compare the t-statistic to the critical value for a one-tailed test from a t-table.
Okok, thank you a lot!
So, do I have to pick the right tail to test if c(6)>c(5) testing on EViews c(6)-c(5)=0?
The tails are symmetric. Of course, if the estimated c(6) is greater than the estimated c(5) then you can't reject the hypothesis no matter what the t-statistic is.
I didn't know all of this, test wald is great, but I go directly to -> Prob(F-statistic)
H0: c(2)=c(3)=0
H1: c(2) != c(3)
if p>5% ---> accept H0
otherwise rejected
maybe false
H0: c(2)=c(3)=0
H1: c(2) != c(3)
otherwise rejected
maybe false
abd wrote:I didn't know all of this, test wald is great, but I go directly to -> Prob(F-statistic)
H0: c(2)=c(3)=0
H1: c(2) != c(3)
otherwise rejected
maybe false
I'm not sure if there is a question here. (Do note that H1 isn't quite right, as c(2)=c(3)=17 would lead to a rejection of the null.)
noted. then H1: each one is != 0
Thank you
Thank you
Actually, the alternative is that either one is not equal to 0.
Users browsing this forum: No registered users and 32 guests
