I use EViews 11 student version on mac. I cannot see Serial Correlation LM test under Residual Diagnostics, where it normally should be there according to http://www.eviews.com/help/helpintro.html#page/content/testing-Residual_Diagnostics.html.
Only sources I am able to see is as attached. Since my Durbin-Watson value <2 and I also want to check for higher-orders, I need to look at Serial Correlation LM. Can you please guide me how I can apply the LM test?
Thanks,
Ayca
Serial Correlation LM Test N/A in EViews11SV?
- Screen Shot 2021-03-09 at 11.28.42 PM.png (16.44 KiB) Viewed 5338 times
Re: Serial Correlation LM Test N/A in EViews11SV?
Not available for panel estimation.
Hmm, I see. So, besides Durbin-Watson test, do you have any suggestion to check serial correlation?
Having the same problem and a response would be highly appreciated.
Lindo
Lindo
http://www.eviews.com/help/helpintro.ht ... es.html%23
Toward the bottom of the Least Squares section is a Wooldrige example demonstrating a test for serial correlation.
Note that if you have a small number of fixed effects, you can sometimes change the workfile to unstructured and use @expand to include fixed effects. That way you get access to more diagnostics.
Users browsing this forum: No registered users and 20 guests
