STAR output issues
Re: STAR output issues
Postby EViews Glenn » Wed Aug 30, 2023 1:37 pm
On the original wonky test output... we've identified an issue with the scaling of some collinearity diagnostics. We are testing a fix and hope to have something soon.
Many apologies, and thanks for your patience.
somordha
Postby somordha » Wed Sep 06, 2023 4:38 am
Glenn, hopefully you'll let me know if there's progress on that. Steve
Postby EViews Glenn » Tue Sep 12, 2023 6:01 am
Very sorry about the delay. I wanted to make sure that we sorted everything out correctly.
We've put a fix into the code and testing looks good. It will appear in the next patch (probably early next week).
Thanks for your patience, and I greatly apologize for the inconvenience.
Let me know if you have any other issues or if you are under time pressure.
somordha
Postby somordha » Mon Sep 18, 2023 3:30 am
Thanks Glenn, when the patch is out I'll tackle and revert.
Thanks for your help.
Postby EViews Glenn » Wed Sep 20, 2023 7:27 pm
It's up. Take a look.
somordha
Postby somordha » Wed Sep 27, 2023 10:56 am
Checked out that patch Glenn. Seems to solved some of the problems but I ran on another dataset from a published paper to double check and can't replicate results. Can I PM you the output?
somordha
Postby somordha » Thu Sep 28, 2023 7:19 am
Also, should the delay parameter be entered as a positive or negative number? I get all NAs for errors and t values when I enter as a negative.
Users browsing this forum: No registered users and 6 guests
