graph issues in eviews 13
Posted: Mon Nov 14, 2022 12:06 pm
by bogrady
I am dealing with 2 graph issues:
1. When pasting a graph into Word/powerpoint, the lines on the graph are "fuzzy" almost like dots. I haven't figured out how to make them solid.
2. My PPT/Word isn't recognizing a saved chart and isn't linking.
Re: graph issues in eviews 13
Posted: Mon Nov 14, 2022 1:08 pm
Is your copy of EViews 13 up to date? (Help->EViews Update)
Posted: Tue Nov 15, 2022 2:03 pm
by bogrady
Yes. We just loaded it.
I did figure out the "fuzzy" issue. the new Eviews seems to default to the opacity setting being "auto" at 75%. Changing it to 100% fixed the problem.
However, the linking problem has not been resolved.
Posted: Tue Nov 15, 2022 3:10 pm
Could you provide more details on the issue?
Posted: Mon Nov 21, 2022 10:39 am
by bogrady
I am trying to paste in what I am seeing but it isn't working. Essentially in PPT, when I use "paste special", the "paste link" is greyed out, and the Source is shown as "unknown". I am assuming there is something I need to turn on either in PPT or in eviews but haven't figured it out yet.
Posted: Tue Nov 22, 2022 1:45 pm
by EViews Katerina
What type is the EViews object you are trying to paste (is it always a graph)? Also make sure when you paste as link your workfile is saved/named. If you try to paste as as link an object from UNTITLED workfile then the source (in paste special as link) will be grayed out.
Posted: Mon Nov 28, 2022 9:43 am
by bogrady
I am aware of that and have named the charts. It's almost like powerpoint doesn't recognize eviews.
Does the update require renaming charts already named and linked?
Posted: Tue Nov 29, 2022 11:48 am
by EViews Katerina
You can verify if your link (EViews work file location and object) is still valid by doing the following:
1.On Powerpoint open your file
2.On the menu click : File
3.On the left pane click : Info
4.On the bottom of right pane click : Edit links to files
5.You can check if the link is still valid by clicking update link.
I am attaching a screen shot of a link I created.
Posted: Wed Nov 30, 2022 11:59 am
by bogrady
Here is the fix for future reference.
One of the the "register components" is "com automation & OLE". When we installed the recent EViews 13, that component wasn't registered. Our administrator just registered it and linking has returned.
