I've been having trouble with a program storing series from a workfile into a database. An error pops up saying the "db_name.e1a database was not found," but the "db_name.e1a" file is always there when I check in the folder. It's weird because this error only happens sometimes, and I run this program often to create new databases. After I rename the database the program runs fine. Do you have idea why this might be happening?
Thanks.
Error storing series to database
Re: Error storing series to database
What's the exact command you are using?
This is the command I'm using:
dbcreate {%dbname} as db
store(d=db) *
store(d=db) *
Weird. Nothing springs to mind. Is it a network location? Perhaps there's disk or network io issues going on.
Yes, I'm storing the database to a network location. I'll check if something is wrong with that. Thanks for your help.
Users browsing this forum: No registered users and 13 guests
