Page 3 of 3
Re: BPTest (Breusch-Pagan LM test for random effects)
Posted: Fri Jul 20, 2012 2:01 am
by suhal
additional information, i used eviews 7, add in lm test already download, equation: group01
thanks
Posted: Fri Jul 20, 2012 8:08 am
by EViews Esther
The BPTest addin will work from the equation object. Please specify your equation first and then run this addin.
Posted: Sat Aug 04, 2012 5:57 pm
by yasir
Dear All,
Why does this test so long? It takes up my processor and memory but crashes in between without displaying results. I have test it with a very small data and it works but my panel data is 142 countries, 17 years, 6 variables. As I write this, Eviews is still processing and displaying not responding. My Eviews is 7.1, and computer is Core i5, 64bit Windows 7 and 8 GB Ram, how much more does it require?
Posted: Sat Aug 04, 2012 7:08 pm
It couldn't hurt to apply the free updates to bring your version uptodate.
Posted: Sun Aug 05, 2012 5:24 am
by yasir
Great... It works perfectly after updating to Eviews 7.2. Thanks alot and keep improving this remarkable software.
Posted: Tue Sep 04, 2012 7:57 am
by stephaniega
Hello!
I have a fixed effects model using panel data. I want to test if the residuals are normally distributed and that they are not autocorrelated. I have not found a test for this when using a fixed effects model.
Any ideas? And if there is not a function to do this in the program, is there any way to do this manually?
Sincerely
Stephanie
Posted: Tue Sep 25, 2012 6:46 am
by Moises
when I run the Breusch-Pagan add-in for the object "Equation: MQOAGRUPADO" in the attached file I receive the following message:
Matrix or vector given non positive dimension in “MATRIX(0,5) _D1T01”
Could you help me with this problem?
Thanks,
Moises
Posted: Wed Sep 26, 2012 8:31 am
by EViews Esther
Please reinstall this addin and do the BP-test again.
Posted: Wed Sep 26, 2012 11:44 am
by Moises
Thank you. Now it works.
Posted: Fri May 23, 2014 2:30 am
by Erikvanaal
I have a question concerning the add-in BPTest. I specified my equation but then when I want click on: Add-ins--> Breusch Pagan Random Effect LM Test, it gives an error saying: Procedure can only be run from Equations estimated by list. What does it mean? Thanks in advance!
Edit: I use Eviews 8
Posted: Fri May 23, 2014 1:06 pm
You must specify your equation as a list of variables, not as an expression (e.g. Y X1 X2 C, rather than Y=C(1)*C(2)*X1)
Posted: Sun May 25, 2014 4:01 am
by Erikvanaal
Ok thanks now it works. However when I do the test I get an error identical to what other forum members also have. It says: 'Out of memory in .....' Does it mean that the memory problem is also not fixed for eviews 8 and that I should use older versions? If so, which version do you suggest then?
Posted: Tue May 27, 2014 2:40 pm
by EViews Esther
This implies that your dataset is too large so that the SLM test cannot be performed. I would suggest to exclude the SLM test from the list for now.
I will figure out how to deal with the large dataset problem.
Posted: Sat Apr 25, 2015 4:21 pm
by Alfiya
EViews Gareth wrote:You must specify your equation as a list of variables, not as an expression (e.g. Y X1 X2 C, rather than Y=C(1)*C(2)*X1)
Could you tell me, please, where I should write such expression as Y=C(1)*C(2)*X1 for getting appropriate results of BPTest?
Posted: Wed Sep 22, 2021 8:52 am
by Basil Oberholzer
Dear All,
I am running a panel data model with EViews 10. However, when I want to run a Breusch-Pagan LM test for random effects, the software tells me "not available with this estimation method". But I am using normal pooled OLS to test for it without any random effect already being defined. What is wrong?
Thanks for any hint.
