I have used the Scenario feature in Models before, but am having trouble now. An exogenous tax variable, COAL_T120, is specified and the baseline forecast for the model works fine -- just as long as it is not fixed by the Scenario. But when it is fixed, I get the error message "COAL_T120_1 is not defined."
Note that this exact character string does not appear in my VAR or the subsequent System I used to build the Model. So I don't know where to find this string in order to correct it.
exogenous variable in model "not defined"
Re: exogenous variable in model "not defined"
It sounds as though perhaps you have overridden COAL_T120 in scenario 1, which informs EViews to use the values in the series COAL_T120_1 rather than the underlying series COAL_T120. If the COAL_T120_1 series doesn't exist, EViews will error.
OK, sorry -- everyone can ignore this little post. I figured it out. I can't "treat as exogenous" a variable via the Scenario function if it's already been defined as exogenous. That was my mistake.
Users browsing this forum: No registered users and 25 guests
