EViews32Com.exe Entry Point Not Found in seats.dll
Posted: Thu May 27, 2021 3:05 pm
I started having trouble with the x13 command. I think it works but I was trying to use a stored spec file and when I did that, it seemed to be running fine (the .out and .d11 files are fine), but the seasonally adjusted data was all NA when it was imported back to the eviews workfile. I need to figure out what is going on there, but first...
I decided to do an uninstall/reinstall.
Now I get this error message during the installation.
Eviews32Com.exe - Entry Point Not Found
The procedure entry point _TAKEDETTRAMO@44 could not be located in the dynamic link library c:\program files\Eviews 10\seats.dll.
I was trying to install the 64 bit so I was surprised that it said Eviews32Com.exe.
My copy of eviews is a EViews 10 Single User Standard license.
Any idea what the problem is? If I am not using seats, does it matter? The rest of the installation seemed to work.
If I upgrade to v12 will this go away?
Thanks,
Jeff
Thanks,
Jeff
