Gregory-Hansen Cointegration Test
Re: Gregory-Hansen Cointegration Test
It works well now! Thanks a lot QMS Gareth! thanks also to trubador!
Sorry, I have a problem when I run the code selecting regime shift (that is, selecting 4 in the part "call greghansen(log_pce_r_pc,independents,4,"aic",8)"). Eviews gives this message of error: "Near Singular Matrix in "Do_ghc.ls Y C (@trend>35-2) G".
Again you should post your workfile along with the code. "Near Singular Matrix" is a very common error, so it is difficult to determine the problem without seeing the original files.
Here is the workfile with my code. Thanks.
Another question: if the potential structural break is at the end of sample (that is, 2004q1), GH test can ascertain it?
- my_workfile.wf1
- (57.61 KiB) Downloaded 1051 times
- prog_gh_prova.prg
- (4.88 KiB) Downloaded 1686 times
You should group your variables outside the program (in the command line for instance). Otherwise, each time you run the code with different independent variables it adds these variables into the same group (e.g. independents), which ultimately leads to singularity. Therefore, I suggest you to form your group of variables first and run the code later with supplying the name of the group as input. Please do not forget to generate a new group when you decide to work with a different set of variables.
In the command line type the following one at a time:
Then in the program window simply call the subroutine:
Regarding to your second question, please note that the analysis is based on sequentially generating dummy and trend variables and the trimming parameter adjusts your sample to allow this type of analysis. In the code above, the parameter is set to 0.15, which means 15% of observations from both ends will not be checked for a break. If your sample is large enough, you can lower the value of this parameter without any loss of generality. However, you should keep in mind that doing so might lead to a/n meaningless/infeasible trend variable.
group independents
independents.add log_ylyt_r log_stnw_r log_nstnw_r fedf_n
I have tried to create independently the independents group in the line command and then recall it in the program as you suggested. But it appears the same error of near singluar matrix. If you have a little time you can prove. Thanks.
I have also tried to reduce the trimming (I have simply change the line command: "!trim = 0.15" with "!trim = 0.05") but the same message error appears ("near singular matrix in do.ghc.ls Y C G (@trend>23-2)).
- prog_gh_prova.prg
- (4.8 KiB) Downloaded 794 times
- my_workfile.wf1
- (50.03 KiB) Downloaded 703 times
There are missing observations in your variables. Re-sizing the range of your workfile to 1952Q2 2012Q1 would do I guess.
I have tried to reduce the sample to 1955q1 2009q2, but the same error appears.
Resizing the sample will not work. You should adjust the range altogether, which means there should be no missing values in your variables in the beginning. Of course, this is just a workaround for now to help you make some progress on your study. I'll try to figure out something else, if the problem is really caused by these missing values.
I have generated a new workfile in eviews without NA at the beginning as suggested by trubador. The code now works well. Thanks a lot trubador!
hello sir
i am completely new to e-views.was trying to run the gregory hansen code in eviews 5 but the software reports this error:
@CMIN is an illegal or reserved name in vector min_t_lag = @cmin(GHtest)..
also if u can refer me some link whr i can read more details about reading codes!!
thank you
thank you
That is because the function is not supported in earlier versions of EViews. Please try the modified version below. For more information on the use of EViews' programming features, please refer to the manual and the examples listed in EViews' directory...
'Gregory-Hansen Cointegration Test
'Reference: Gregory, A. W. and Hansen, B. E. (1996). "Residual-Based Tests for Cointegration in Models with Regime Shifts", Journal of Econometrics, Vol. 70, pp. 99-126.
call greghansen(y,x,2,"aic",6)
' Arguments
'series Y ' dependent variable
'group G ' group of independent variable(s) (including single series)
'scalar Model ' 2 = Level Shift, 3 = Level Shift with Trend, 4 = Regime Shift
'scalar Maxlag ' Maximum number of lags for unit root testing
'string %Criterion ' Selection criteria for unit root testing (i.e. aic / sic / hqc)
subroutine greghansen(series Y, group G, scalar Model, string %Criterion, scalar Maxlag)
smpl @all
!trim = 0.15
!maxlag = Maxlag
!n = @obs(y)
!nindep = G.@count
!lower = @round(@obs(Y)*!trim)
!upper = @round(@obs(Y)*(1-!trim))
matrix(!upper-!lower+1,4) GHtest
equation ghc
Table GHZ
GHZ(1,1) = "THE GREGORY-HANSEN"
GHZ(2,1) = "COINTEGRATION TEST"
if Model=2 then GHZ(3,1) = "MODEL 2: Level Shift"
else if Model =3 then GHZ(3,1) = "MODEL 3: Level Shift with Trend"
else if Model = 4 then GHZ(3,1) = "MODEL 4: Regime Shift"
endif
endif
endif
GHZ(5,1) = "ADF Procedure"
GHZ(7,1) = "t-stat"
GHZ(8,1) = "Lag"
GHZ(9,1) = "Break"
GHZ(11,1) = "Phillips Procedure"
GHZ(13,1) = "Za-stat"
GHZ(14,1) = "Za-break"
GHZ(15,1) = "Zt-stat"
GHZ(16,1) = "Zt-break"
for !ref = 2 to 4
GHZ.setwidth(!ref) 15
GHZ.setlines(a4:b4) +d
GHZ.setlines(a6:b6) +d
GHZ.setlines(a10:b10) +d
GHZ.setlines(a12:b12) +d
for !i = !lower to !upper
if Model=2 then
'MODEL 2 - C: LEVEL SHIFT MODEL
ghc.ls Y c G (@trend>!i-2)
ghc.makeresid res
uroot(adf, none, info={%criterion}, maxlag=!maxlag, save=level) res
GHtest(!i-!lower+1,1) = level(3,1)
GHtest(!i-!lower+1,2) = level(2,1)
call phillips(res)
GHtest(!i-!lower+1,3) = !Za
GHtest(!i-!lower+1,4) = !Zt
else if Model=3 then
'MODEL 3 - C/T: LEVEL SHIFT WITH TREND MODEL
ghc.ls Y c @trend G (@trend>!i-2)
ghc.makeresid res
call phillips(res)
'MODEL 4 - C/S: REGIME SHIFT MODEL
for !g = 1 to !nindep
G.add (@trend>!i-2)*G(!g)
ghc.ls Y c (@trend>!i-2) G
ghc.makeresid res
call phillips(res)
for !g = G.@count to !nindep+1 step -1
%name = G.@seriesname(!g)
G.drop {%name}
endif
endif
endif
vector(3) break
!i =1
while !i<=!upper-!lower+1
if GHtest(!i,1) = @min(@columnextract(GHtest,1)) then
break(1) = !i
endif
if GHtest(!i,3) = @min(@columnextract(GHtest,3)) then
break(2) = !i
endif
if GHtest(!i,4) = @min(@columnextract(GHtest,4)) then
break(3) = !i
endif
!i = !i+1
wend
GHZ(7,2) = @min(@columnextract(GHtest,1))
GHZ(8,2) = GHtest(break(1),2)
GHZ(13,2) = @min(@columnextract(GHtest,3))
GHZ(15,2) = @min(@columnextract(GHtest,4))
GHZ(9,2) = @otod(break(1) + !lower - 2)
GHZ(14,2) = @otod(break(2) + !lower - 2)
GHZ(16,2) = @otod(break(3) + !lower - 2)
show GHZ
delete res level GHtest break
endsub
subroutine phillips(series y) 'MATLAB code of this routine is available at Bruce E. Hansen's website: http://www.ssc.wisc.edu/~bhansen/progs/joe_96.html
!n = @obs(y)
equation eq1.ls y y(-1)
!be = eq1.@coefs(1)
series ue = y - !be*y(-1)
'Bandwidth selection
!nu = @obs(ue)
equation eq2.ls ue ue(-1)
!bu = eq2.@coefs(1)
series uu = ue - !bu*ue(-1)
!su = @sumsq(uu)/@obs(uu)
!a2 = (4*!bu^2*!su/(1-!bu)^8)/(!su/(1-!bu)^4)
!bw =1.3221*((!a2*!nu)^0.2)
!pi = @acos(-1)
!j=1
!lemda = 0
while !j <= !bw
series temp = ue*ue(-!j)
!gama = @sum(temp)/!nu
!w=(75/(6*!pi*!j/!bw)^2)*(@sin(1.2*!pi*!j/!bw)/(1.2*!pi*!j/!bw)-@cos(1.2*!pi*!j/!bw))
!lemda=!lemda+!w*!gama
!j=!j+1
wend
series temp = y*y(-1) - !lemda
!p = @sum(temp)/@sumsq(y(-1))
!Za = !n*(!p-1)
!Zt = (!p-1)/@sqrt((2*!lemda + @sumsq(ue)/!nu)/(@sumsq(y(-1))))
smpl @all
delete eq1 eq2 ue uu temp
endsub
I would like to test cointegration with two unknow regime shifts, as Abdulnasser Hatemi-J(2008) "Testing cointegration with two unknown regime shifts with an application to financial market integration". The program code (Gregory -Hansen Cointegration Test) you provided above tests for one unknown regime shift. My programming skills are very poor therefore I would appreciate your help me to update the above code.
I would appreciate your response.
Kinga
Kinga
- Tests for cointegration with two unknown regime shifts.pdf
- (134.04 KiB) Downloaded 1460 times
Dear Mr. Trubador and Mr. Gareth, I'm a researcher in Brazil and found this code very useful for my studies. I started making the corrections for earlier versions as presented by Mr. Gareth and everything run alright. I used 1 dep. variable against 3 indep. variables. Well, my difficulty is that I want to run the test using just 1 dependent variable against 1 independent variable, or even 2 independents variables, but the program even returns the results for 1 dep. against 3 indeps. So I have two questions: (a) how to perform the test in such a way(s); and (b) why the test do not perform the Wald statistics? Thank you very much in advance. Margalef.
Hi Trubador,
I need some help on the G-H cointegration. Is there any way to get the coefficients of the Gregory-Hansen cointegration? I mean coefficients such as those included in Eviews' Johansen's cointegrating equation.
Thanks in advance.
Gordeza
Thanks in advance.
Gordeza
Users browsing this forum: No registered users and 11 guests
