Rolling VaR estimates
Stu
Postby Stu » Sun Aug 11, 2013 7:51 am
Stu
Re: Rolling VaR estimates
Postby Stu » Sun Aug 11, 2013 4:16 pm
trubador
Did you use forum search?
Postby trubador » Mon Aug 12, 2013 2:30 am
Suppose you have a return series called rt. Then, for EWMA you can try:
!alpha = 0.02 'you should provide an appropriate value for this parameter
smooth(s,!alpha) rt^2 ewma
And as for GJR with t-distribution:
arch(1,1,thrsh=1,tdist) rt c
Finally, to obtain the lower %1 quantile of a series y:
scalar q1 = @quantile(y,0.01)
Please note that, all these commands (and many more) are available in the users guide.
Stu
Postby Stu » Mon Aug 12, 2013 7:25 am
Stu
Postby Stu » Mon Aug 12, 2013 8:34 am
I run the programs, but it keeps showing up error messages. And have tried to adpat the codes, but couldnt figure out what the problem is!!
Could someone please help, by perhaps even giving some hints at the problems? I very much appreciate your time!
Thanks.
Stu
Postby Stu » Mon Aug 12, 2013 9:40 am
Stu
Postby Stu » Mon Aug 12, 2013 9:51 am
Postby EViews Gareth » Mon Aug 12, 2013 10:41 am
%smpl = @str(!i) + " 1250"
scalar x = @elem(ewma, %smpl)
Stu
Postby Stu » Mon Aug 12, 2013 11:05 am
Gareth,
When i run it, it shows up 'Illegal date 1 1250 in “scalar x = @elem(ewma, "1 1250")"
What could be the problem here?
Postby EViews Gareth » Mon Aug 12, 2013 11:07 am
Sorry, I posted without thinking.
I don't understand what you're trying to do with that line. @elem takes a single date, not a range of dates.
Stu
Postby Stu » Mon Aug 12, 2013 11:13 am
Stu
Postby Stu » Mon Aug 12, 2013 12:51 pm
Postby EViews Gareth » Mon Aug 12, 2013 1:04 pm
scalar x = @elem(ewma, "1251")
Stu
Postby Stu » Mon Aug 12, 2013 1:13 pm
trubador
Postby trubador » Tue Aug 13, 2013 1:23 am
I tried to modify your code so as to perform what you want and to give you the idea for further adjustments. However, I suggest you to go over An Introduction to Eviews Programming before moving forward.
!window = 1250
!length = @obsrange
!alpha = 1-0.94 '1-alpha is the coefficient of estimated variance
!scale = 10000 'it might be a good idea to adjust the scale
series x 'create the output series beforehand
matrix(!window,!length) results 'you can create a matrix to store all the resulting smoothed series
' move sample !step obs at a time
for !i = 1 to !length-!window
  smpl @first+!i-1 @first+!i+!window-2
  smooth(s,!alpha) !scale*returns^2 ewma
  stom(ewma,ewmat) 'convert series to a vector
  colplace(results,ewmat,!i) 'place the vector into the matrix
  x(!window+!i) = ewma(!window+!i)
smpl @all
Users browsing this forum: No registered users and 12 guests
