TGARCH
For questions of any nature based on EViews 5 or earlier versions of EViews.
rahma
TGARCH
Postby rahma » Fri Mar 22, 2013 7:11 am
Hello :)
I am just starting to learn Eviews, and i don't have enough time to finish my research, can you please show me how to estimate this TGARCH eq
= c0 + c1e2cot-1 +(-)dt-1e2cot-1 + c2 sigman t-12
trubador
Did you use forum search?
Re: TGARCH
Postby trubador » Sat Mar 23, 2013 4:34 am
The file attached might give you the idea...
Demonstration of TGARCH estimation in EViews
rahma
Re: TGARCH
Postby rahma » Mon Mar 25, 2013 6:26 am
I am using Eviews4, can you explain to me what is the mean equation and the variance regressors? Sorry i am still learning
James017
Re: TGARCH
Postby James017 » Mon Nov 02, 2015 11:59 pm
The critical values are differ slightly but I believe that's because in EViews 4.1 we used the newer critical value simulations. Bottom line is that at least for this specification, there are no appreciable differences between versions. What specifications are you using???
31. http://www.chessrivals.net/
Return to “EViews 5 and Earlier”
