Marginal Effects
micha
Marginal Effects
Postby micha » Tue Apr 07, 2009 10:07 am
Hi there,
I use a probit model and my dependent variable has two categories.
My question: Is there an easy way to calculate the marginal effects of my independent variables?
If you have an solution, please describe it as simple as possbile, since I'm not so familiar with all this technical stuff :lol:
Thanks,
micha
PS: I use Eviews 6
Re: Marginal Effects
Postby EViews Gareth » Tue Apr 07, 2009 10:23 am
The manual has a good discussion of this. Look under "Procedures for Binary Equations" in Chapter 30.
micha
Postby micha » Tue Apr 07, 2009 11:13 am
Thanks for your answer!
I’ve looked it up in the handbook. Just to get sure:
1) I have my estimation output
2) Then I click on “Proc”, Forecast
3) There I click on “Index – where Prob = 1-F(-Index)”
4) Then “Proc” and “Make Residual Series”, let’s say name xy
5) Afterwards I multiply each single independent variable with @dnorm(-xy)
Is that right?
I’m so sorry for that stupid article, but as I’ve mentioned it, I need it simple :lol:
Thanks again,
micha
Postby EViews Gareth » Tue Apr 07, 2009 11:36 am
In step 5 you multiply by the coefficient, not the independent variable.
micha
Postby micha » Tue Apr 07, 2009 11:43 am
Just to get that right: let's say one of my exogenous variables is "age" an its value in my estimation output is 0.5
So I mulitply 0.5*@dnorm(-xy) and the result is the marginal effect. Is that correct?
Thanks again!
Postby EViews Gareth » Tue Apr 07, 2009 11:47 am
right.
micha
Postby micha » Tue Apr 07, 2009 1:42 pm
Once again thanks for your patience!!
Economist
Postby Economist » Thu Dec 10, 2009 7:48 pm
I am also working on a probit model, and I would like to see the marginal effect of a categorical variable on the dependent variable, in particular, the marginal effect of higher education on the probability of being poor. I checked the "Procedures for Binary Equations" which QMS Gareth suggested but for some reason, the advice on this part couldn't work in Eviews. In other words, when I click Proc, I don't see anything like "Forecast (Fitted Probability/Index)" or "Make Residual Series" button. By the way, I am using Eviews 6. So I couldn't calculate with that way and I am sort of stuck. I tried another way to calculate it but it didn't give expected results. I mean the results are by far higher than expected. Let me share my code here, and I would appreciate if somebody advises me to overcome this problem. Thanks in advance.
This is my model;
probit(h) poor4e c reg1 reg2 reg3 reg5 eth2 eth3 eth4 dem2 n_adult n_child ed12 edu5
This is what I tried to calculate the marginal affect of edu5, by keeping all other variables constant at their mean values;
!z_highedu=c(1)+c(2)*@mean(reg1)+c(3)*@mean(reg2)+c(4)*@mean(reg3)+c(5)*@mean(reg5)+c(6)*@mean(eth2)+c(7)*@mean(eth3)+c(8)*@mean(eth4)+c(9)*@mean(dem2)+c(10)*@mean(n_adult)+c(11)*@mean(n_child)+c(12)*@mean(ed12)+c(15)*1
!p_highedu=@cnorm(!z_highedu)
!z_nonhighedu=c(1)+c(2)*@mean(reg1)+c(3)*@mean(reg2)+c(4)*@mean(reg3)+c(5)*@mean(reg5)+c(6)*@mean(eth2)+c(7)*@mean(eth3)+c(8)*@mean(eth4)+c(9)*@mean(dem2)+c(10)*@mean(n_adult)+c(11)*@mean(n_child)+c(12)*@mean(ed12)+c(15)*0
!p_nonhighedu=@cnorm(!z_nonhighedu)
table (2,4)education
education (1,1)="!z_highedu"
education (1,2)="!p_highedu"
education (2,1)=!z_highedu
education (2,2)=!p_highedu
education (1,3)="!z_nonhighedu"
education (1,4)="!p_nonhighedu"
education (2,3)=!z_nonhighedu
education (2,4)=!p_nonhighedu
show education
By comparing !z_highedu and !z_nonhighedu or !p_highedu and !p_nonhighedu, I was hoping to see the marginal effect, but it is way higher than expected :-(
rashid02
Postby rashid02 » Tue Dec 22, 2009 9:14 pm
hi
I am using Probit estimation and want to get marginal effects. previous posting suggest using command of @dnorm(-xy) and then multiplying with the estimated coefficients. I cannot see this series @dnorm(-xy) in the working file, how to get this series and even If I have it then how to get a single value of mariginal effect for each estimated coefficeint?
look forward to someone's suggestions, thanks.
Thesissers
Postby Thesissers » Thu Mar 15, 2012 3:52 am
I would also like to know how to get one value for marginal effects.
I've multiplied this @dnorm(-xy) with my coefficient for a certain variable; but now i get a whole column of values. How do I turn it into one value for the marginal effect of this variabele?
Thanks!
Dewenter
Postby Dewenter » Fri Sep 13, 2013 12:47 pm
I am trying to estimate marginal effects for a logit model.
I have followed the instructions of several prior blogs:
- estimate the logit
- forecast the index and save as indexF
- create scalar: scalar xb = @mean(indexF) (this value is 0.4166)
- create scalar: scalar l_xb = @dlogistic(-xb) (this value is 0.239)
The problem is that some of the coefficient estimates in the logistic regression are quite large, eg 39.8 and 25.2. If I multiply these coefficient estimates times 0.239 I get a number well above 1 which doesn't make sense.
Thanks for your help.
Dewenter
Postby Dewenter » Fri Sep 13, 2013 1:03 pm
O-kay. I have had a follow on thought.
The values I get from those calculations are the change in probability for a 1 unit change in the explanatory variable.
I get the large coefficients for variables with relatively small standard deviations.
So, is it accurate to take the standard deviation for an explanatory variable and multiply it by the value I get from the above calculations and conclude that this is the effect of a one standard deviation change in x?
eg, the 39.8 coefficient estimate I reference above is for a variable with a standard deviation of 0.03. So, (39.8 * 0.23) * 0.03 = 0.275. This tells me a one st dev increase in this variable is associated with a higher probability of 27.5%
Is this a correct interpretation?
Many thanks.
Postby EViews Glenn » Fri Sep 13, 2013 5:02 pm
Those marginal effects are derivatives, not unit change differences.
WerMaximus
Postby WerMaximus » Tue Jun 16, 2015 8:04 am
EViews Glenn wrote:Those marginal effects are derivatives, not unit change differences.
Hi Gleen,
so what would this precisely mean? Sorry for the question, but I am an absolute newbie to statistical analysis.Say I have for a variable a marginal effects coefficient of -0.106. What does this tell me?
Best regards,
Max
arash.hadizade
Postby arash.hadizade » Tue Mar 12, 2019 7:16 am
hi
first estimate your logit model, then name it, like eq1.
write the code below in command box. after each line of code, press enter.
eq1.forecast(i) xbf
scalar meanxb = @mean(xbf)
scalar meffectw = @dnorm(-meanxb)
scalar meffectw = @dnorm(-@mean(xbf))
vector meffects = meffectw*eq1.@coefs
logit marginal effects results are saved in "meffect" as a vector.
Users browsing this forum: No registered users and 10 guests
