TARCOINT
TARCOINT
Postby EViews Gareth » Wed Feb 22, 2012 11:44 am
This thread is about the TARCOINT add-in, written by Eren Ocakverdi (Trubador), that performs the Enders and Siklos 2001 Cointegration and Threshold Adjustment procedure.
trubador
Did you use forum search?
Re: TARCOINT
Postby trubador » Thu Mar 01, 2012 12:35 pm
Professor Siklos, one of the authors of the article "Cointegration and Threshold Adjustment", noted in an email exchange that using an exogenous threshold series may have uncertain statistical implications and therefore threshold series should be derived from the underlying equilibrium relationship. He also suggested that, it would be better to add any exogenous type variables in the ECM portion of the model for the completeness of estimation.
I revised the add-in in light of Professor Siklos' recommendations:
1) Removed the option to supply exogenous threshold series.
2) Added the option to enter regressors into the equilibrium equation.
gordeza
Re: TARCOINT
Postby gordeza » Thu Mar 08, 2012 7:55 am
trubador wrote:Professor Siklos, one of the authors of the article "Cointegration and Threshold Adjustment", noted in an email exchange that using an exogenous threshold series may have uncertain statistical implications and therefore threshold series should be derived from the underlying equilibrium relationship. He also suggested that, it would be better to add any exogenous type variables in the ECM portion of the model for the completeness of estimation.
Trubador, this add-in is really helpful, thanks so much.
is it possible to update the add-in by replacing the current one by the corrected one? I mean the one that include 2) option to enter regressors into the quilibrium equation.
Thanks.
trubador
Re: TARCOINT
Postby trubador » Thu Mar 08, 2012 8:12 am
You already have access to this revised version. Just download and install it from the link given in the very first post of this thread...
trubador
Re: TARCOINT
Postby trubador » Fri Jul 20, 2012 10:59 am
A minor update for the add-in is available (and is already uploaded):
1) You can now adjust delta values in generating random data for endogenous variables. These are simply the coefficients of lagged changes used during simulation, where the lag length is exogenously or endogenously determined. For details, please refer to Equations 11' and 12' in the original study.
Steph
Re: TARCOINT
Postby Steph » Mon Jul 30, 2012 2:40 am
I try to use TARCOINT add-in and I would like to ask you one thing:
You need to specify 2 endogenous variables but I would like to make sure that I estimate yt= a + xt + et and not xt = a + yt + et...
Is the first endogenous variable the dependent variable?
Thanks a lot!
trubador
Re: TARCOINT
Postby trubador » Tue Jul 31, 2012 1:12 am
Steph wrote:Is the first endogenous variable the dependent variable?
Yes, that is correct.
Steph
Re: TARCOINT
Postby Steph » Thu Aug 09, 2012 7:51 am
Thanks a lot for your prompt response.
I am sorry to bother you but I have another question. I would like to add a trend in the long run relationship but I am not sure we can add exogenous variable in the model. Is it possible?
Thanks in advance for your help!
Steph
trubador
Re: TARCOINT
Postby trubador » Fri Aug 10, 2012 1:37 pm
Yes, it is possible. Just create a seperate series for the trend variable (e.g. series tr = @trend) and then enter the name of this variable into the relevant dialog box called "Exogenous variables". Please see the documentation (Add-ins/Manage Add-ins/Docs) for more details.
Steph
Re: TARCOINT
Postby Steph » Mon Aug 13, 2012 12:59 am
I don't know what I did wrong when I installed the package but I don't have a box called "exogenous variables" but I have 2 boxes called 'endogenous variables". When I enter the trend in the 2nd box called "endogenous variables", I get an output table where no exogenous variable have been included.
Do you know if anybody else has ever had this problem?
Thanks for your help.
trubador
Re: TARCOINT
Postby trubador » Mon Aug 13, 2012 3:00 am
It is the second box. I guess there was a typo, when you first downloaded the add-in. You can download the latest update using same link, which is given in the very first post of this thread. Other than that, as it is mentioned in the second post, any exogenous variable will be influential in the ECM model only.
Steph
Re: TARCOINT
Postby Steph » Wed Aug 15, 2012 1:50 am
Thanks!
hhhcj
Re: TARCOINT
Postby hhhcj » Wed Mar 20, 2013 11:23 pm
if the threshold is more than one ,how to estimate it ?
delta_h
Re: TARCOINT
Postby delta_h » Sat Mar 23, 2013 7:51 am
I've the same problem than Steph, when i enter an exogenous variable in the 2nd box called "endogenous variables", the output window doesn't contain the exogenous variable.
I've downloaded the version of the first post like you recommend.
Is there a problem with the program?
Thanks.
PS: I use eviews 7
trubador
Re: TARCOINT
Postby trubador » Sat Mar 23, 2013 1:47 pm
As I mentioned in the second post and reiterated in my response; "any exogenous variable will be influential in the ECM model only". The technique operates on residuals and therefore the output shows only the relevant variables used in those equations. For more details, please refer to the original study...
Return to “Add-in Support”
Users browsing this forum: No registered users and 5 guests
