Library Tech Asis
rbriceno
Library Tech Asis
Postby rbriceno » Fri Jul 22, 2011 11:03 am
Hello. I finished installing "TechAsis" library, that supposedly "provides a group of subroutines that let you calculate technical analysis statistics using stock prices". I understand that add-ins and libraries are installed using the same procedure but instead of seeing a new command under add-ins menu, where do I have to look to find the subroutines associated to Tech Asis?
Re: Library Tech Asis
Postby EViews Gareth » Fri Jul 22, 2011 11:19 am
Since the TechAsis Library is a library and not an Add-in, it is not listed in the Add-ins menu. If you want it to be available from the add-ins menu, you should download the {i]TechAsis add-in[/i].
When you install a library, it just downloads the files and puts them in your EViews add-ins folder, with out installing them as an add-in in EViews.
Return to “Add-in Support”
Users browsing this forum: No registered users and 5 guests
