I wonder if there's a way to remove (specific, not all of them) old add-ins in a program. Let's say I consolidate the functions of several old add-ins into a new one (with a different name) and want to automatically remove the old ones when the new add-in installation begins. I tend to think that the shell code might work, but there is a problem with the addin location. In a regular program, one can do <addin>, but with shell command, I am not so sure about it. Would you please let me know what's the correct way to 1) remove the old add-in, and 2) remove the old add-in registration from the add-in list. Thanks.
Tchaithonov
Deleting old Addins via Program
Re: Deleting old Addins via Program
There isn't a command line method to remove an add-in from the registry, so you're right - you're going to have to do it with some shell commands. The add-in registry is just an ini file stored in your standard EViews ini file location (you can use Options->General Options->File locations to find out where).
Might be easier to automate outside of EViews with some sort of bat file or script rather than using EViews to do it though, if possible.
Return to “Add-in Writing area”
Users browsing this forum: No registered users and 11 guests
