Error in using FRB/US supply side package in EViews 11
joshi27s
Postby joshi27s » Sat Jun 20, 2020 7:51 am
Hi, I am trying to run the program in FRB/US supply-side package. It contains two programs and three subroutines. To run, I did:
run frbus_supply_estimation
Then, to create the estimates of the states, I typed:
run frbus_supply_filter
It resulted in the following error:
Screen Shot 2020-06-20 at 10.39.44 AM.png (117.48 KiB) Viewed 4129 times
Could you please help me resolve the error?
Re: Error in using FRB/US supply side package in EViews 11
Postby EViews Steve » Sat Jun 20, 2020 3:21 pm
While these are EViews programs you are running, it would be more appropriate to ask the people that actually wrote the program, since they know most about it.
But I did do a quick google search for "FRM/US supply side package" and found the zip file you're running these programs from. I found opened the frbus_supply_filter.prg and looked for the COPY command that is being used. Here's the command lines (showing 1 before and 1 after):
wfopen saved_results
copy saved_results::untitled\saved_results kf_data::untitled\{%modname}
wfclose saved_results
freeze({%modname}_results) {%modname}.ml(m=100,showopts)
It looks like the copy command is trying to copy an object named "saved_results" from the Untitled page in the saved_results.wf1 workfile. I found a workfile with that name in the zip file and looked in it and there isn't any object named "saved_results" in there.
I then looked at the end of the first program you are running (frbus_supply_estimation.prg) and it saves a new workfile named saved_results_new.wf1.
wfsave saved_results_new
Perhaps the saved_results object is in that workfile instead?
These are just guesses on my part since I don't know the details of what these programs are trying to do. But I would open the saved_results_new workfile that was saved by the first program to see if there's an object in there named "saved_results". If so, then the second program is just opening the wrong workfile. Or the first program is saving the results with the wrong name. In either case, it's a bug with their program.
joshi27s
Postby joshi27s » Sat Jun 20, 2020 7:05 pm
Than you, Steve, for the helpful explanation. It turns out that the object "saved_results", is indeed within the saved_results_new workfile.
