Patch silent install
nightbird
Postby nightbird » Mon Jun 01, 2020 12:39 pm
I successfully installed version 11 in silent mode ("EViews11Installer(64-bit).exe" -s /sms -f1.\setup.iss -f2.\setup.log), but I can't install the patch in silent mode as well ("EViews11x64Patch_052720.exe" -s, /S, -silent, -quite, -s -sms...) - only in interactive mode. Is it possible to install the patch in silent mode?
nightbird
Re: Patch silent install
Postby nightbird » Mon Jun 01, 2020 1:15 pm
Response:
The same way:
"EViews11x64Patch_052720.exe" -r -f1.\patch.iss
After:
"EViews11x64Patch_052720.exe" -s /sms -f1.\patch.iss -f2.\patchlog.log
Postby EViews Jason » Mon Jun 01, 2020 2:42 pm
I am not clear on your second post, but to answer your question the answer is yes.
You will need to create an iss file using the patch executable (in the same way you stated in the second post).
I just confirmed you can run the patch silently as well, but used
"EViews11x64Patch_052720.exe" -s -f1.\patch.iss
mike7065
Postby mike7065 » Mon Aug 03, 2020 9:39 pm
While installing the patch silently for existing eviews 11 users, we are getting error in the install log as result code =-3 and some files are deleting from eviews folder unable to lanuch eviews icon says file not exist. after uninstalling completely and when i start installing eviews after eviews install patch is installing without error.
Postby EViews Jason » Tue Aug 04, 2020 3:46 pm
Please send me an email to jason@eviews.com. Include any applicable screen shots, the install log, and the *.iss script file. Also in your email, specify which version of EViews are you using (11, 10, etc and 64 or 32 bit).
