Eviews 9 clustered standard errors
drake
Postby drake » Sat May 30, 2020 2:34 am
is there clustered standard errors option in Eviews 9? How can I do this?
Thanks in advance
Re: Eviews 9 clustered standard errors
Postby EViews Gareth » Sat May 30, 2020 7:47 am
There is nothing built in.
You'll have to perform it manually, or upgrade your version.
drake
Postby drake » Sun May 31, 2020 5:01 am
ok thanks. How can I build it manually?
drake
Postby drake » Sun May 31, 2020 11:56 pm
If I have an unbalanced panel and I estimate a fixed effects equation, with the fixed periods on the effects specification, can I use the coef covariance method "white cross-section" to have a robust estimation for cluster?
Postby EViews Glenn » Mon Jun 01, 2020 7:59 pm
White period is cross section cluster robust.
drake
Postby drake » Wed Jun 03, 2020 6:08 am
thank you
drake
Postby drake » Wed Jun 03, 2020 6:53 am
what are the difference between white period and white cross section?
Postby EViews Glenn » Fri Jun 05, 2020 10:31 am
White period allows for intra cross-section (between period) correlation. White cross-section allows for intra period (between cross-section) correlation.
